Spectrum modem not working. Will Nest thermosta continue to work as programmed
DougK
My modem is down.  Cannot connect to Nest Thermostat.   Will Thermostat continue to work as currently programmed?
@DougK
Yes it will.
Thanks.  I'm 3000 miles away and it's freezing back home.
GabrielaG
Hi @DougK,
Thanks for reaching out to the Google Nest community. I understand that your Spectrum modem is not working properly, and you are concerned about if your Nest Thermostat will work as you programmed.
Thank you for your response @Patrick_Caezza.
I just want to know if all of your concerns were clarified or if you have any other questions.
Gabriela
