02-04-2022 12:22 PM
My thermostat suddenly disconnected from Heat Link and wont reconnect. Checking battery condition on technical info the readings are as follows
Battery 3.92v
Vusb 5.10v
Vin 0.00v
Lin 200mA (c)
Why is Vin 0.00v and is this the cause of the problem. What is the solution?
The system was installed in June 2019
Thankyou
02-07-2022 04:10 AM
Thanks for letting me know.
Could you tell me please when did the situation start occurring first and when was the thermostat installed?
Also, please answer to the following questions:
Are there any lights on the Heat Link? Does the boiler activate when calling for heat by pressing the Heat Link's button to activate Manual Mode?
Are you seeing any wiring report or error on the thermostat and/or the app?
Have you had any recent power cuts in your area? If yes, has the power been restored?
Have you recently had service or maintenance on your electrical, plumbing, or heating system?
If yes, how long was the power off for? (Be specific.)
Could you tell us please if you've checked on the breaker switch and fuse box?
Any blown fuse in there? Have you tried to turn the breaker switch off and on again? Any difference?
02-09-2022 04:20 AM
Hi, I wanted to check in. Do you need any further assistance? If so, make sure to let me know.
02-11-2022 06:25 AM
Since I haven't heard from you in a while, I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
