08-24-2022 09:28 PM - edited 08-24-2022 11:10 PM
I have a nest GA02081-US-1 which I've had for several months. It has worked fine, and I have an older version of the nest upstairs.
Starting tonight, around 10:00, I noticed the house was getting hot downstairs. I then begin to try to reconfigure the thermostat, and verified all the wires were correctly connected. I then did a factory reset.
I set the temperature to cool to 76. But no matter what I do, despite it saying cooling, it stays around 81 because it seems only the fan will blow and only minimal cold air from vents.
So I went upstairs and verified that air conditioner is working fine. It is.
What am I missing here? Why is only the fan operating but cold air is barely coming out of the vents, keeping the temperature at 81°?
| Nest Thermostat |
08-30-2022 12:19 PM
Hey DaCapitan,
I wanted to follow up and see I could be of any help. I found an article that has some troubleshooting steps. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
08-30-2022 01:28 PM
Turns out it was an HVAC issue(no freon due to leak). Thanks!
08-30-2022 01:51 PM
Hiya DaCapitan,
I'm glad to hear that you were able to track down the issue! In that case, did you have any other questions or concerns we can address today?
Jeran
09-02-2022 04:48 PM
Hi DaCapitan,
Chimin in-- do you have other questions regarding this? Let us know by responding to this, otherwise we'll be locking the thread in 24 hours.
Princess
