01-14-2023 03:57 PM
A difference … the temp sensors on the old home show up individually on the home page so I can see the temperature sensed by that sensor. On the recently added home, the temp sensor I added to that home and thermostat does not appear on the home page but the thermostat does. Not sure why?? When I click on the thermostat display, I can see the temp sensor sensed temp as well as the thermostat sensed temp
01-19-2023 04:49 PM
Hi JohnP,
Thanks for posting.
Could you confirm how you paired it with your Nest Learning Thermostat? Did you do it without the app?
Mel
01-23-2023 03:47 PM
Hi JohnP,
Edward
01-25-2023 05:36 PM
Hi JohnP,
Edward
01-25-2023 05:55 PM
Temp sensor recently lost its connection to the thermostat. I removed it and reinstalled it, but it would not pair with the thermostat. Getting real tired of reinstalling the thermostat in Oder to get the senor to pair with it
01-27-2023 02:06 PM
Hi JohnP,
Thanks for the response. Could you tell us the message that you're getting when the sensor when it fails to pair?
Edward
01-30-2023 02:34 PM
Hi JohnP,
Edward
01-31-2023 02:39 PM
Hi JohnP,
Edward
