10-28-2024 09:03 PM
Hello, I’m getting an error “no power on r”. Having read a bunch of docs I think I don’t need to wire in c; nest should work on battery (which is up to 3.9 volts). However I still get no power.
What am I missing?
thanks
10-28-2024 09:12 PM
@hkhattri The Nest Learning Thermostats can detect the presence of the wire inserted in the R terminal. It then checks this wire for power by internally connecting to Y, G, and/or W to see it creates a current load. If it does not it reports the error of no power on R. Make sure your R wire was stripped to the proper length and is fully inserted.
AC Cooling Wizard
10-28-2024 09:27 PM
Thanks so much for the quick response. Yes, the R wire is connected properly. In fact it’s been working for a few years.
anything else I can check?
10-30-2024 09:22 PM
Would be great if there is anything else I can try. Thanks in advance
10-31-2024 11:15 AM
if you have a digital or analog volt on multimeter, you can use it to verify that the air handler transformer is outputting the proper 24 V AC power. It’s possible that the transformers gone bad or that the fuse supplying the power has tripped inside the control board.
AC Cooling Wizard
11-01-2024 10:37 PM
Thank you @CoolingWizard
