12-03-2023 10:24 AM
Thermostat E went off and cannot access it as it shows a symbol looking like a download manual image
cannot get past this on the thermostat so cannot access settings
12-05-2023 04:49 AM
Hi there, thanks for reaching out! I'm so sorry to hear about this situation. Could you tell me what's the error message that appears in the Nest app?
12-05-2023 11:38 AM
Hi
before the screen locked it was H151, but now cannot get past the download image on the screen of the thermostat
12-06-2023 03:54 AM
Thanks for clarifying. Do you have it in the Nest app added and showing as offline or was it removed from there?
12-09-2023 07:33 AM
Hi there, just checking in with you. Did you manage to check the last message?
12-10-2023 05:49 AM
Hi, no joy
still cannot get pat the download image on the thermostat
12-12-2023 06:33 AM
Can you press once on the button on the Heat Link to see if any LED lights turn on?
12-14-2023 06:38 AM
Hi, I wanted to check in. Did you see my colleague's message? Keep us posted.
12-14-2023 10:00 AM
I did and I replied that I cannot get past the download image on the thermostat and that on the heat link, on first press, I have blue light, 2nd press, green light & heating comes on.
12-14-2023 10:02 AM
12-18-2023 03:30 AM
Have you tried to pair the thermostat with the app to see if the screen changes at all?
12-18-2023 11:04 AM
Hi
Yep, no joy.
The thermostat is simply stuck on the download image and cannot get past it.
I fear the nest is empty and I will need to replace it
12-20-2023 02:24 AM
Got it. Would it be alright if I send you an email to the address associated with your Community account?
12-20-2023 10:29 AM
Yes, that would be fine
12-26-2023 02:01 AM
Hi there, did you manage to check my email?
12-31-2023 01:12 AM
Hi there, just checking in with you. Did you manage to check my colleague's last message?
12-09-2023 08:00 AM
I thought I did
still cannot past the download app image on the thermostat
