12-19-2022 04:51 AM
Entry key for my new Thermostat doesn't work in Nest app. It does work in Google Home.
But I cannot connect extra sensors without the Nest app. I have tried on Android and Chrome Web Browser.
12-22-2022 11:29 AM
Hi Tonphanan,
Thanks for posting ― let's get this sorted out.
A few questions: what Nest Thermostat do you have? Check this link to know what thermostat you have. Also, what troubleshooting steps have you done so far?
Mel
12-22-2022 12:45 PM
A regular Nest Thermostat. I have found out only E and Learning are compatible with the app and the sensors.
12-23-2022 10:35 AM
Hi Tonphanan,
You're right, the Nest Temperature Sensor works with the following thermostats:
Check this link for more details: Learn about the Nest Temperature Sensor
Mel
12-26-2022 11:45 AM
Hey there Tonphanan,
Mel
12-27-2022 12:01 PM
Hi Tonphanan,
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
12-27-2022 12:03 PM
I'm good. Thank you
12-28-2022 01:36 PM
Hi Tonphanan,
You're welcome. Feel free to create a new thread if you have other questions or concerns as I will be locking this thread now.
Mel
