Thermostat offline and i'm away from home
Jac101
I'm new to nest and had a thermostat installed.  I'm now away from home and the nest app says offline.  All the trouble shooting solutions require physical presence at the thermostat to resolve. Hoe can I fix when I'm way from home? Also, I set to eco before I left, will this keep the temperature at the settings applied? Thanks so much to anyone that can help
David_K
To troubleshoot it, you will need to physically be with the thermostat unfortunately.
Nest thermostat is offline
