06-11-2022 10:48 PM
My boiler is heating at full pelt but the thermostat is only showing 10 degrees and nothing stops the boiler apart from turning it off.
I can then restart the boiler and the thermostat will behave ok and then it will just heat at max while not effecting the temp on the thermostat.
I guess this has gone faulty. It’s less than 6 months old, Will the retailer will replace ??
is this a common fault ?
thanks
06-15-2022 12:32 PM
Hi AB71,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. I'd love to know more about this and I have a few questions:
Edward
06-18-2022 01:36 PM
Hi AB71,
Edward
06-19-2022 02:29 PM
Hi AB71,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
