05-05-2023 05:08 PM
My AC is offline , not able to connect to wifi
05-05-2023 05:31 PM
Are you trying to remotely connect to your nest thermostat over the Internet? Are you having difficulty because your nest thermostat is no longer connected to Wi-Fi in your home?
i’m afraid you need to provide more details of what you were trying to do.
AC Cooling Wizard
05-05-2023 05:32 PM
Yea I cannot connect it through the app , and the physical device never worked after the set up
05-05-2023 05:34 PM
Google home is the app I used to set it up
05-05-2023 05:43 PM
If you have a Nest Thermostat, it only uses Google Home App. The Nest Learning Thermostat uses the Nest App to install and setup the Learning Thermostat
The AC Cooling Wizard
05-05-2023 06:07 PM
Tks for answering , it was working without problem before it got disconnected from the wifi
05-10-2023 08:01 AM
Hi Ayh1,
Thanks for reaching out, and I’m sorry to hear about the situation. Let’s sort this out.
A few questions: does it show offline in the Nest or Google Home app or is it indicated on the Nest device? Are other non-Nest devices in the home offline? Has there been any recent change in the home Wi-Fi network? Lastly, is the Wi-Fi router or access point within a reasonable range (1 to 15 meters) of between three and fifty feet from the Nest devices?
I’ll look forward to your response.
05-13-2023 08:54 AM
I wanted to check and see if you managed to see the information I shared. Please let me know if you have any questions from here. I would be happy to assist and make sure you are good to go.
05-14-2023 02:04 PM
I appreciate your help, @CoolingWizard and Zoe.
