07-28-2023 05:26 PM
My Nest Generation 3 suddenly stopped working and went dead. It will not restart and all fuses and wiring have been checked. Wifi works fine on everything else. Can the internal battery be replaced?
08-05-2023 05:23 PM
I can’t get that info for you because I can’t restart the thermostat it’s dead. It was fine a week ago but now doesn’t work at all and it’s very warm
08-12-2023 03:09 PM
Plugged it in to a USB to recharge. Gave me a E74 error and now it’s dead again.
08-05-2023 08:38 AM
Hi Batonmom,
Thanks for posting here in the Community forum, and I'm sorry to hear about the situation. Please answer the following:
Also, if still possible, please help us with the power readings of your Nest Learning Thermostat by going to its Settings > Technical Info > Power (Battery, VOC, VIN, and lIN).
08-05-2023 05:23 PM
08-08-2023 09:53 AM
Thanks for getting back to us. Since your thermostat is not turning on at all, kindly get a micro-USB cable and a USB charger and use them to plug the thermostat’s display into a power outlet and leave it plugged in for an hour. After an hour of charging, put the thermostat display back to its base, and then let me know how it goes.
08-12-2023 12:17 PM
Hello Batonmom,
08-12-2023 03:09 PM
08-19-2023 11:34 AM
Don't give up on us yet. We'd like to further check on this. Could you fill out this form and let me know once you're done?
Kind regards,
08-22-2023 11:06 AM
Hey Batonmom,
We've received your form; thanks for filling it out. Please keep an eye on your email, as someone from our team will reach out to you to assist you further. We'll leave this topic open for another 24 hours in case there are any follow-up questions or comments. Please let me know if you need more assistance.
All the best,
