2 weeks ago
It says the RH isn't connected but it is. I can't even use the thermostat because of it.
2 weeks ago - last edited 2 weeks ago
You need to ensure the RH bare copper wire is straight, and proper length. Ensure it is fully inserted. If you forgot to turn off the power before you removed your old thermostat and installed the new Nest thermostat, you might of caused short circuit that blew the 3-amp fuse on the HVAC control board.
if the information I provided, you helped you to understand your problem hit the “kudos up thumb.” If the information provide, you solved your problem, please hit the “recommend this answer” button.
The AC Cooling Wizard
