Trane XV20i variable speed heat pump
Turtle
Does the Nest Learning Thermostat manage the variable speed capability of a Trane XV20i or does it in essence convert it to a 2 stage system?
2 Recommended AnswerS
This will answer your question.
https://support.google.com/googlenest/answer/9259652
Correct
7 REPLIES 7
So, when the article says it will run the variable speed fan at a single speed am I correct in interpreting this as meaning that I will lose the benefit of the variable speed HVAC if I use the Nest Learning Thermostat with the unit?
Thank you
Ryan_G
Hope this helps!
Kind regards,
Ryan
Ryan_G
Hope this helps!
Kind regards,
Ryan
Correct
Ryan_G
Hey Turtle,
We'd like to check if you've seen Patrick_Caezza's response. Let us know if you need more help and we'll be glad to assist.
Thanks for your assistance, Patrick_Caezza.
Ryan
Ryan_G
Hey Turtle,
Ryan
