01-27-2023 08:14 AM
I have just installed a new nest thermostat and to my disappointment it does not seem to be capable of controlling two heating zone and hot water? The old control system from EPH allowed separating settings and on-off times for each zone - ground floor, first floor and water. Nest only seems capable of setting on-off times for water and all heat.
Is there anyway to add another zone so I can control the heat for each zone separately?
Many thanks
01-30-2023 03:32 AM
Hi there! I'm sorry to hear that the thermostat is not behaving as you expected it to, but one thermostat can only control one zone, and as you said, on a basic level, it is an on/off switch for the boiler. If you want to control two separate zones, you will need an additional thermostat for the second zone.
02-02-2023 03:35 AM
Hi there, just checking in, did you manage to see our message above?
02-03-2023 06:56 AM
Hi there, as you haven't replied, we're just gonna go ahead and close the case. Let us know if you need anything else. Have a great day ahead!
