12-05-2023 05:31 AM
I have a home with 10 nest thermostats (Model 3.7). Some of them will connect to the wifi and some will not. I have tried to reset the few that do not and still same issues. I have learned from my neighbours that tthey also had defective ones which resulted them sending the bad ones back to get replacements. These are 5 new houses that were built together so same batch for all Nest would have most likely been used. I understand that if I provide the serial numbers you can check to verify they are defective. Please let me know how I should provide this.
12-05-2023 12:22 PM
Call Google Nest Support on 0808 169 2307
They will help you progress
Cheers
12-06-2023 05:56 AM
Much appreciated will give them a try.
12-10-2023 01:35 PM
Thanks for chiming in, @SeriouslyWhy.
@TLALEX, uh-oh! I'm sorry to hear that your thermostat is not connecting to Wi-Fi even after resetting the thermostat. Have you tried to reach out to our customer support team already? If not yet, let me check on this for you.
