Upgrade to add hot water
jdixon
I have a first gen. Nest thermostat controlling the heating only. I have a separate programmer for the hot water.
Is it possible to upgrade the Heatlink to enable nest to control the hot water and heating.
Thanks, J
Frustratedddd
No
CristianC
Hey @jdixon,
Thanks for reaching out. You can install a 3rd Generation Nest Learning thermostat and Heat Link. It will control both your heating and hot water.
jdixon
Thanks. It’s unfortunate that you have replace everything. Apart from the cost, it’s wasteful.
CristianC
Thanks for your feedback, @jdixon. If anything comes up, let me know.
