Water heating
SmokeyCC
Hi there I am a little confused on the setup with multiple nest thermostats.
UK
If my DHW domestic hot water 2 port motorised valve is connected to the SL switched live (terminal 6) of one of the Heat Links.
Is hot water controlled from that single thermostat?
Can I alter the HW on another Nest thermostat which isn’t connected to the motorised valve.  I’m assuming the relay for call for hot water operates in all NEST thermostats?
Is this assumption correct?
Thanks
 Chris
SmokeyCC
Does anyone know the answer to this regarding multiple heat links controlling hot water?
