Which nest thermostat will work with my system?
Dray871
2 REPLIES 2
HVAC
Any of them up to you which model and functions you’d like.
Thanks for posting in the Google Nest Community forum. I'm sorry for the delay. It looks like you have a conventional system. Your system is compatible with the Nest Thermostats.
You can follow this wiring configuration: The Nest Thermostat doesn't use any jumper wires.
  • G - Green (Fan)
  • W/W1 - White (Heating)
  • C - Blue (Common)
  • Y/Y1 - Yellow (Cooling)
  • R/RC/RH - Red (Power)
Also, you can visit this support article for more information.
I appreciate your input, @HVAC.
