11-02-2021 05:51 PM
All of a sudden one of my thermostats lost connectivity w wifi. I have restarted the network and it’s fine. I restarted the thermostat as the online help suggested and nothing. Any ideas. By the way the other two are doing fine
11-02-2021 06:28 PM
I just started having the same issue with one of my thermostats. Not sure how to fix this.
11-02-2021 06:35 PM
I am having the same exact problem. Why are the Nest thermostats not connecting to wifi? If it's a system error I hope it gets fixed soon. Now I will have to set it manually. SMH.
11-02-2021 08:42 PM
Mine as well. It won’t charge and it’s not turning my heat on. I am over NEST rn.
11-03-2021 07:52 PM
Appears to be a major issue introduced with the latest firmware update.
