02-05-2024 01:54 PM
I’m getting bids for a new home HVAC system. Lennox EL23/SLP99 lists a Lennox S30 Communicating Thermostat for the modulating variable speed system. In my existing home, I have a Nest thermostat working with a Daikin FIT inverter air conditioner & modulating variable speed furnace. The Lennox thermostat S30 and S40 seem expensive, waste screen space and I prefer Nest. But the question I can’t get answered is whether a Nest thermostat can work with Lennox. Thanks for any advice and insight!
02-05-2024 04:04 PM
@Trooker , the Lennox SLP99UHV series have an advanced control board that supports both an advanced digital communicating thermostat, such as the Lennox S30. In addition it also has a conventional HVAC connection terminal that the Nest will work with. Make sure your contractor deletes the S30/S40:from the offer, and simply installs a 10-conductor, 18-AWG thermostat cable between the air handler and the thermostat location. You set up your Nest Learning Thermostat as a 2-Stage gas heating furnace and 2-Stage Air Conditioner.
Know that your Contractors is going to tell you that if you use a Nest thermostat with this furnace, that you’re gonna lose some efficiency that’s designed into the system between the SLP99 and the EL23 outdoor unit, Now here is the truth, the EL23XCV outdoor unit has very sophisticated, built-in control sensors on the suction and discharge refrigerant pressures as well as temperature sensors for the ambient outdoor air, the suction return line temperature, and the liquid line temperature. As a result, the system will still operate extremely efficient even if you’re using a conventional thermostat system to control the whole thing, This information is provided courtesy of Lennox to its licensed contractors. So you do not have to use an S30/S40 thermostat in order to get the efficiency, the system has to offer. What you will actually lose is the ability for the system to self diagnose probable system failures and report them to the indoor unit and onto the S30/S40 thermostat and you will loose the WiFi remote configuration capability of the system. This will require the contractor to do a little extra manual configuring of the system for maximum operational performance.
AC Cooling Wizard
02-06-2024 12:57 AM
@Trooker , my congratulations for upgrading such highly efficient Air Conditioner and Furnace. When you install your Nest Learning Thermostat you will should have the following wires:
Rc - Power 24VAC from SLP99UHV
Y1 - Stage 1 Cooling
Y2 - Stage 2 Coling
W1 - Stage 1 Gas Heat
W2 - Stage 2 Gas Heat
G - Blower Fan
C - Power Common
Your HVAC a contractor will need to make the necessary configuration changes to the SLP99UHV control board. The Nest supports the needed 2 Heat / 2 Cooling stages for what Lennox describes as a non-communicating thermostat. There is a bridge wire labeled W915 on the control board that will need to be cut so the Nest can control both stages of cooling.
AC Cooling Wizard
02-05-2024 04:04 PM
AC Cooling Wizard
02-06-2024 12:57 AM
Y2 - Stage 2 Coling
G - Blower Fan
C - Power Common
AC Cooling Wizard
02-15-2024 08:25 AM
This is great news! Thank you, @CoolingWizard , for the detailed response and solid answer. The remote wifi control isn't an issue as I work primarily from home office. The remodel includes sealing all air leaks after replacing the sheathing and insulation, hoping to mitigate the potential loss of HVAC efficiency.
02-29-2024 02:08 PM
I am being told that if I revert to a simple thermostat like my Nest Learning will only operate at 70% or 100% of its capacity like a two speed unit. Is this correct? Is there a way to program the unit to operate at say 30-50% and 100%?
03-01-2024 09:17 AM
@CTopher , The Nest Learning Thermostat can support up three fan speeds. L, M,H.
AC Cooling Wizard
03-01-2024 11:38 AM
I am considering a Lennox EL23XCV with a SL280 Furnace.
What specifically do I need to request wire side as well as configuration of the unit and the Nest?
Does the Nest 3rd speed = dehumidifier function?
Will I be able to set AC fan speed option something like 30%, 70% & 100%?
Do you have a recommendation of speed settings for most efficiency in Texas heat/humidity?
Will the Nest handle the 2 speed heat as well as the 3 speed AC?
Thank you for the help and feedback.
CTopher
03-04-2024 04:55 PM
The Nest Learning Thermostat is a programable thermostat. It can support multiple functions however there are limits. Take the * terminal. This can programmed to be either Stage-3 Heat (W3), Emergency Heat (E), Humidifier/Dehumidifier(HUM/DHUM) or 3rd Speed Fan. It cannot be programmed to be a Humidifier and a 3rd speed fan at the same time. Basically there are limitations.
