Will current wiring work with Nest - no C wire
Ctownclaw
Houptee
Silver Product Expert
B is the C common wire on this system.
You will need a Nest Learning model to handle 2 stages of heat and cooling.
Just make sure you know if you have a heat pump when you wire it up because the screw labels on this are "inner for non heat pumps" and use the "outer labels for a heat pump system".
Jhonleanmel
We appreciate your help here, Houptee.
Ctownclaw, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Mel
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
