Nest battery
b53c53d82
Nest says battery low replace.
Where do I buy one?
6 REPLIES 6
b53c53d82
Please call me 812-890-9000
Houptee
If you have the Nest (non learning) the one you touch the side to change temp then it uses alkaline AAA batteries. Pull Nest off the base and you will see the batteries.
If you have the Nest Learning model or Nest E model that you rotate the dial, then the battery is internal and not replaceable.
Houptee
Read this about changing the batteries or if it is the Learning Nest or Nest E you can charge it with a phone charger and a micro USB cable.
https://support.google.com/googlenest/answer/10119271?hl=en#zippy=%2Chow-to-replace-the-batteries
Jhonleanmel
We appreciate your help here, Houptee.
b53c53d82, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Mel
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
