12-29-2022 02:12 PM
Thermostat wiring:
PC board wiring:
If one follows the app it stops if you've got a dual fuel system and tells you to pay someone to come install it. I've installed many of the Nest thermostats for others w/o dual fuel with no problem. The "recommendation" of hiring pro installation is ACTUALLY a requirement? Ecobee doesn't do this and if I have to spend more for Nest installation, I'll spend the extra on an Ecobee.
01-04-2023 04:19 PM
Hi Blake23452,
Thanks for reaching out. If you have a dual fuel system, We suggest to have a trained professional set up your thermostat. It’s important for a professional to assess the requirements for your specific dual fuel configuration since choosing incorrect options for a dual fuel system can result in damage to your system. You can click on this link to learn about our Nest Pro services.
Edward
01-09-2023 11:25 AM
We appreciate your help here, EdwardT.
Blake23452, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
01-10-2023 11:43 AM
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
