12-15-2022 11:01 AM - edited 12-15-2022 11:02 AM
I had some issues when I first setup the wiring for the nest, but was able to get the A/C to work during the summer. Now that it’s winter I’m having issues blowing cold air when the heater is on. I made sure to open the valve on the heat pump and give it some time to run, but it still blows cold air. I have attached some pictures of the previous thermostat wiring, the nest wiring, and the heat pump unit for reference. Any help would be appreciated.
12-20-2022 06:43 PM
Hi RobE,
Thanks for reaching out. I'm a little confused about the wiring of your Nest Thermostat. If you have a heat pump, there should be a wire connected to the OB terminal of your Nest Thermostat. Could you share the labels where the wires are connected to on your previous thermostat?
Edward
12-26-2022 04:42 PM
Hey RobE,
Edward
12-27-2022 05:45 PM
Hi RobE,
Edward
