convert Samsung thermostat wall controller mwr-sh00n to nest thermostat
Al0724
Hello at home I’ve been installed a Samsung central unit and the wall controller is model MWR-SH00N , I open it and only have to wires … can someone Tell me what to do … so I can enjoy nest thermostat or If its possible … thanks
ovidioj
Hello @Al0724,
Thanks for posting in the community.
I appreciate the information you have provided so to determine the compatibility of your HVAC system with a Google Nest Thermostat, I'd recommend using the Nest Compatibility Checker. This online tool allows you to input details about your system, such as the manufacturer, model, and thermostat wiring, to get a personalized assessment.
Note: Always take a picture of your current thermostat’s wires before you remove it from the wall and install a Nest thermostat. This picture is an essential reference to identify wires and correctly install a Nest thermostat.
Identify a thermostat wire: Checking your system's control board is a very reliable method for determining what an unknown wire is. The control board’s connectors typically have labels that can tell you what each wire is when other methods aren’t convenient or don’t work.
Note: If you find a wire label not listed here, or you find a wire labeled Other, you need to contact a pro to check compatibility and have your thermostat installed. We recommend you contact Nest Pro technician.
Please let me know if you have any questions. Thank you.
Jorge
