help with 7 wire installation
markanski
i have seven wires
e
aux
y
g
o
r
c
any ideas where to hook up on nest 3rd gen
Hello markanski,
Thanks for reaching out to us! I'd be happy to take a look into this for you.
To provide you with accurate guidance, I'll need some additional information. Can you let me know the colors of each wire and their corresponding labels or letters on your current thermostat? Tell us the make and model of your HVAC system and what type it is. This information will help me assist you in identifying the correct connections for your Nest Thermostat.
