08-31-2022 06:13 AM
I came back home from being away for a few days and my thermostat had no wifi connection. When trying to correct I discovered I had forgotten the PIN. Without wifi on the thermostat I cannot change the PIN from the app. Help!
09-03-2022 05:29 AM
If you've tried the usual things like restarting your thermostat and router and it still won't reconnect to Wifi, then follow these steps:
If the Nest drive is successfully showing up on your computer, can you see a technicalinfo.PLIST file? If you get this far let me know and I'll ask a community specialist to assist with next steps, as these can't be shared publicly in the community.
09-03-2022 05:29 AM
09-07-2022 09:39 AM
thanks David.
I contacted Nest tech support and they walked me through the process. It worked and I am now up and running.
Thanks to all who helped,
Gerry
09-07-2022 09:44 AM
Hiya NHgerry,
I'm glad to hear that David and Nest Support were able to help you out! In that case, did you have any more questions for us here on the forum?
Jeran
09-10-2022 10:02 AM
Melba
09-07-2022 08:50 AM
Hey there NHgerry,
I'm just checking up on this thread, did you have any more questions or need any additional help?
Thank you for helping out on this thread, David!
Jeran
