05-31-2025 04:32 AM
I have read articles about using a USB cord to charge but where do I find the connection? I have looked at the owners manual and no where does it say there is even one to connect.
06-03-2025 10:11 AM
Hi crownpt,
Thanks for reaching out here in the community! It seems like your Nest Learning Thermostat (3rd gen) has a low battery, and you're having trouble finding the charging port despite checking the manual. No worries, I’d be happy to help with this!
The micro-USB port is on the back of your Nest Learning Thermostat's display. You'll need to gently remove the display from its base to find it. A 30-minute charge is usually enough, but a fully drained battery could take up to 2 hours. For reference, see this article: Nest thermostat USB port.
If your Nest thermostat still shows a low battery after charging it, please confirm the following:
Keep me posted.
Jenniffer
