08-11-2023 12:34 PM
08-11-2023 12:57 PM
Can tell me label under the blue wire? I think it is OB and you have a heat pump system
AC Cooling Wizard
08-11-2023 01:25 PM
OB is the label there
08-11-2023 01:30 PM
You have a Heat Pump system with auxiliary heat. What model of Nest Thermostat did you acquire?
AC Cooling Wizard
08-11-2023 01:39 PM
nest learning gen 3
08-11-2023 01:40 PM
not getting power......thought i had the breaker off BUT i did not.......could i have blown an ac unit fuse?
08-11-2023 02:03 PM
Ok, so here is the wiring for your Nest Learning Thermostat.
Red Wire, Nest Rc
White Wire, Nest W2/Aux
Blue Wire, Nest OB
Yellow Wire, Nest Y1
Green Wire, Nest G
Brown Wire, Nest C.
Set your system Equipment as Heat Pump, Type O, Forced Air. The will automatically detect the W2 wire will assign it to Auxiliary Heat.
AC Cooling Wizard
08-15-2023 11:08 AM
Thanks for posting in the Google Nest Community forum. I just want to check if you managed to see the response above. Please let us know if you still have questions or concerns, as we'll be willing to assist you further.
I appreciate the help, @CoolingWizard.
