01-22-2022 03:49 PM
I have a new williams in wall gas garage heater direct vent and need to know if a nest thermostat is compatible to control this by wifi
02-02-2022 06:06 PM
Hi Eng,
Thanks for reaching out to the Google Nest Community and sorry for the delay.
Could you provide the exact model of your furnace? Also, please provide a photo of the wires of your old thermostat so I can check on it. You can also check your system’s compatibility before purchasing a Nest thermostat with our online Compatibility Checker.
Melba
