which Nest Model will work
erikking18
 I have modelg4cvz
below is what have
Stuff
Tape off the brown E/W1 wire and any will work.  If you want separate emergency heat control then you need the 3rd Gen Learning version.
Your system is only compatible with the Nest 3rd Gen Learning Thermostat.
You can wire it like this
Red - R to Rc
Orange - O to OB
Black - C to C
Yellow - Y1 yo Y1
Brown - E/W1 to *  (set as Emergency Heat)
Green - G to G
White - W2 to W2
MelbaDT
Thanks for the detailed answer and suggestions, Patrick_Caezza and Stuff.
erikking18, I'm chiming in to check if everything is covered here. Let us know if you still have questions.
Melba
MelbaDT
Hey erikking18,
Checking back in — how's your thermostat now?
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
