wiring help for Trane system - heating when on cool
lbdgolfer
I have a Trane thermostat with Cooling and 2 stage heat. I have wired it up but when the Cooling should be on it is blowing heat. I found the wiring manual for the original thermostat and confirmed the wiring for the nest.
Thermostat pictures
@lbdgolfer
You have a heat pump system and must use the labels at the bottom.
Give this wiring a try,
White - W1 to W2/AUX
Green G to G
Orange - O to O/B
Blue - B to C
Yellow - Y to Y1
Red - R to Rc (jumper to RC not needed)
2 REPLIES 2
@lbdgolfer
Green G to G
Orange - O to O/B
Blue - B to C
Yellow - Y to Y1
lbdgolfer
@Patrick_Caezzathat corrected the cooling issue. When I tested the heat I wasn't getting any hot air but will retest in the morning.
