11-08-2023 08:23 AM
I can't set up google wifi
- I have downloaded the google home app
- I have the google wifi connected into the router with 3 different ethernet cables and it still shows up "orange"
- I have the google wifi connected into the power socket
- On my phone, the google wifi adapter never came up as an available device
- I have plugged in all three pucks in hopes that one worked
Questions:
- Is this broken? Do I need a new one?
- Is there a way to fix this
11-08-2023 11:37 AM
Reset it then try adding it again to the app.
https://support.google.com/googlenest/troubleshooter/13816290?hl=en&visit_id=638350689947305749-3974...
11-11-2023 12:48 PM
Hi taiwantuna,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Which Google/Nest router are we working with? Have you tried the steps provided by mattmc111111111? If so, how was it? Does the child point broadcast the setup Service Set IDentifier (SSID) or network name located at the bottom of the device? Also, do you have the Internet from your modem?
Give these steps a try:
Let us know how it goes.
Dan
