Help with googlw wifi and sonic
Lolitaw
We previously had xfinity and google wifi router wired to their modem.  There were 2 additional points that created a mesh network.  We recently changed to sonic fiber and they installed the modem so it connects to a cat 5 port in our house which the google wifi router is wired to.  The router showed as offline in the Google home app and the two points showed as weak signal.  The installer then connected the router back into another port which is wired to a switch and activated to ports for that switch so we could hardwire the two points.  The wifi works fine but they still show as offline in Google home.  We have some areas with thick walls so wanted to add a few more Google wifi points so we could extend the coverage.  Because Google home thinks everything is offline I can't connect the additional points.  I've tried removing the wiring  to see if we could do all mesh but it still shows offline.  Any tips for how I can make this work?  We don't have cat 5 in the areas where we want to put the additional points so that isn't an option.
7 REPLIES 7
olavrb
I answered a similar issue here:
Hope it's helpful. 🙂
I don't work for Google.
Jeff
Hi, Lolitaw.
I just wanted to jump in real fast to see if you saw olavrb's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
Lolitaw
Thanks for checking.  It didn't seem to work, but I ended up unplugging the three old wifi points and doing a factory reset.  I was then able to install the three new ones to create a new mesh network.  Then I added the old wifi points to the new mesh network.  Coverage is still a bit weak in some areas even with the three new points so may experiment with trying to connect some points using ethernet again when I have time.
Jeff
Hi, Lolitaw.
Sorry to hear that the first wave of troubleshooting didn't work out. Have you had a chance to try things with the ethernet connected?
Jeff
Hey, Lolitaw.
I just wanted to check back in and see if you saw my last message there. Let me know if you still need some help.
Thanks.
Jeff
Hi, everyone.
Thanks.
Jeff
Hi, everyone.
Thanks
