Nest Wi-Fi Pro upload speed less than 100 Mbps
ishan747
I just installed a 3 Nest Pros and the upload speed on Wi-Fi seems limited by Nest Wi-Fi pro. I have AT&T Fiber 1 Gbps symmetrical, which I get if I'm using AT&T's router. However, after enabling IP Passthrough the Nest pro provides 600-700 Mbps DL but stays less than 50 Mbps UL.
Set-up:
AT&T Fiber 1 Gbps speed
IP Passthrough on ATT router
1 Nest pro router connected to ATT router with CAT 6 ethernet
1 nest pro wired backhaul
1 nest pro Wi-Fi backhaul
David_K
If you're confident the IP passthrough settings are set correctly, try these additional steps from a user on the AT&T community:
https://forums.att.com/conversations/att-fiber-equipment/att-fiber-and-google-nest-wifi/61f2d65b08dc...
AbigailF
Thanks for lending a hand, @David_K.
@ishan747, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
Dan_A
Hi ishan747,
Dan
Dan_A
Dan
