Nest Wifi Pro Point Question
Gherb72
I purchased 2 Nest Wifi Pro Routers (without Points), with the intent to space them out in my 2 story home.  After setting up my network with the first Nest Pro, how can I have to second Nest Pro to connect as a access point working in tandem with the Primary Nest Pro Router?
MetalGlacier
Product Expert Alumni
They are identical so just go through setup the same way and it will figure it out.
Jeff
Hi Gherb72,
I just wanted to jump in real fast to see if you saw MetalGlacier's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
Jeff
Hey Gherb72,
I just wanted to follow up once more to see if you were still needing some help here. If so, just let us know.
Jeff
Jeff
Jeff
