07-20-2023 04:19 AM
My setup is as following:
Nest Wifi Pro 1 ---> Switch 1 ---> Switch 2 --Nest Wifi Pro 2
The first week the Pro 2 shows up as wired but now it shows up as wireless in the Home app. The connectivity led on the switch is green and blinking, nothing has changed in my setup or configuration.
How come? I've rebooted the devices multiple times, same with the switch.
07-20-2023 08:36 AM
What exact switches do you got? Brand, model. Some unmanaged and most managed switches can have conflicting features, like loop detection/prevention, like STP (spanning tree protocol). On a managed switch this feature should be disabled to work well with Nest Wifi.
07-20-2023 10:44 AM
Switch 1: Sitecom LN-121
Switch 2: Linksys LGS116P
07-20-2023 11:16 AM - edited 07-20-2023 11:21 AM
Both switches has 802.3x flow control. Netgear says:
I think that can be a problem.
Edit: Never mind. The switches I regularely recommend, Netgear GS105/8/16 and TP-Link TL-SG105/8/16, has this too. Hmm.
07-20-2023 11:26 AM
Here is a previous thread on the same topic:
Sunmary of suggestions is to not mix wired and wireless backhaul, and to make sure ISP equipment is in bridge/bypass mode to avoid double NAT.
07-23-2023 02:38 AM
I've set the modem in bridge mode rebooted all the devices but still wireless.
When I temporarily connect them directly with a cable then it shows 'wired'.
07-23-2023 05:50 AM
Alright. I've escalated the thread, Google staff should make the next move.
You could try to remove the switches from the equation, plug an ethernet cable directly from the primary unit LAN port to a secondary unit WAN port, and see it it stays on "wired". Just to make sure it's not any of the switches causing this.
07-24-2023 12:42 PM
Hi SpaceCow,
That certainly hasn't been easy for you!
Before we proceed to the next steps, could you confirm if the troubleshooting steps olavrb provided work? This is to ensure that we know what the next steps are.
Dan
08-02-2023 12:56 AM
When I wire it directly without switches it shows up as 'wired'.
The weirderst is that the first week it worked perfect. Is there a chance the cable causes this? I've replaced all the CAT5e to 6 (and give the 5 away so I can't check it for now...)
08-02-2023 05:12 AM
Interesting. Could be the cables, or could be the the switches. Netgear GS108 or TP-Link TL-SG108 are my go-to.
08-09-2023 09:06 PM
07-27-2023 03:41 PM
Hey SpaceCow,
We want to ensure you are good to go. Please reply to this thread if you still need assistance so we can give you a helping hand.
Lovely
07-27-2023 11:00 PM
Hi, currently on holiday so I will check next week.
07-28-2023 12:13 AM
Hello SpaceCow,
Gotcha! I'll keep your thread open for a few days and wait for your news. Enjoy your holiday.
Lovely
08-01-2023 02:40 PM
Kimy
08-10-2023 06:54 AM
I feel so stupid... because of all the re-wiring i've accidently not plugged in the second switch (with the UTP). What happened is that the second Nest Pro became a wireless bridge between the two switches...
Because I had a connection I didn't think about that.
Sorry for the inconvenience.
08-10-2023 05:19 PM
Hey SpaceCow,
Ah! No worries. We’re glad to hear that this has been sorted out, and thanks for sharing the resolution here. This may help us isolate the same issue in the future.
Let us know if there’s anything else we can help you with.
Warmly,
Kimy
08-13-2023 08:50 PM
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Kimy
