06-06-2022 01:40 PM - edited 06-06-2022 01:41 PM
Pretty frustrated. Setting up a Nest Wifi out of a factory sealed box and not my first Google mesh network. Router is up and running, but both Wifi points say they need to be activated.
The help center link provided only talks about TV.
Forum search reveals people talking about a "device utility" app in the Play Store, but when I search for that Google Home is the only result.
What exactly are the necessary steps to activate my brand new wifi points?
And yes, I've rebooted them and my Pixel 5a.
06-06-2022 02:49 PM
See following blog post about it:
06-07-2022 12:11 PM
Thanks for the link. Ended up chatting with tech and they have been less than helpful, just stepping through the steps that I already know don't work. That the Device Utility app is missing from the Play store was news to them. So far, no solution.
06-08-2022 01:53 PM
Hey, cappyfield.
Sorry about the issues you're seeing on setup here. That sounds really confusing and frustrating. Would you mind telling me where in the process it tells you that the activation is required? Are you able to start the setup process at all?
Thanks.
06-10-2022 01:07 PM
Google Home will find the points, but that's where the process halts with the activation process. The usual next step would be to scan the QR code, but that doesn't happen.
06-09-2022 01:28 PM
Thanks for the input there, Wonderbeef.
If you do have access to a second device, it's worth trying to perform setup with that. Be it iOS or Android, sometimes swapping devices is the quick fix to getting around the issue. It's definitely worth a try.
Thanks.
06-08-2022 07:57 PM
Had the same problem from my Pixel 6. Setting up the point on an iPad (within Home app) worked. My guess is Pixels can't use their original communication method because of the Sonos ruling, hence the vague allusions to using a TV. This is incredibly frustrating
06-10-2022 01:10 PM
Thanks all. My final solution was to return the set as defective (thanks Amazon) a 2-pack of Nest routers. These have set up flawlessly.
06-14-2022 02:57 PM
Sounds good, cappyfield. I'm happy to hear you found resolution on this.
Before I mark this as resolved, is there anything else you might need here?
- Jeff
06-20-2022 11:12 AM
Hi, everyone.
- Jeff
