Nest wifi pro
fp3csuF
My new nest wifi pro will not connect to my modem. It's a blade antenna that gets a signal from a microwave dish. I reconnected my old Google wifi that I had factory reset and it got an internet connection right away. I called my ISP and they said everything is DHCP, there's nothing I need from their end.
Thoughts?
7 REPLIES 7
RXShorty
Hi @fp3csu
Did you check different WAN settings so they would match your provider?
Please check THIS link about the WAN settings.
fp3csuF
Hi, thank you for the info. The WAN is set to dynamic as required by the ISP.
Hi @fp3csu
Which firmware version is your Wifi Pro running?
I know that the latest version does fix some issues, the current version: 1.63.355999.
If you have a older version please try to connect your Nest Wifi Pro router to a location that could work with internet. I know it is not easy to do so but worth a shot.
LovelyM
@RXShorty, your assistance is greatly appreciated.
@fp3csu, thanks for reaching out. I want to make sure that you were able to get your Google Nest Wifi Pro working with your modem. Please tell me if you're still encountering issues, and I'll be more than happy to lend you a hand.
Sincerely,
Lovely
LovelyM
Hi fp3csu,
I'm checking in to see if you still need help. Please tell me if you have other questions or concerns. I want to make sure you're all good now.
Lovely
fp3csuF
Hello, thank you for reaching out. I was able to insert an old tp link router between the modem and the nest wifi pro and this made it work.
Alex_S
We're glad to hear that this has been sorted out and thanks for sharing your resolution in the Community. Let me know if we can help you with anything else.
Alex
