01-04-2023 07:08 PM
I have two Rapberry Pi Pico W's . One of them connects to my wifi just fine, the other will not. Both devices have identical model numbers, both are running identical firmware. Running an identical Python script on both, but only one will connect to my home network. My original thought was a bad wifi chip, but I turned on my phone's hotspot and the "bad" one connected to that just fine. I also ran a network.scan() on the bad device, and it was able to find my SSID, so I'm certain that the wifi on the Pico is just fine.
Something in my Google WiFi router must be blocking it for some reason? But I have no idea how to find out why. After some searching, I've come to the unfortunate conclusion that there are no logs available to me. The only thing I have thought of is that I've read that there could be a maximum of 100 devices connected to a hub (I have 2 hubs). I currently have 44 devices online, but I have 56 offline devices....which adds up to 100. Do offline devices count towards the 100? If so, I suspect that would be my problem. So how I do I clean those devices up and kick them off my router so new devices can connect?
01-10-2023 06:02 PM
Hello, thank you for the reply. I was able to figure it out. But to help any one that searches for a similar issue.
The error I was getting on the device was "No Network". I did a scan of the network, and it saw it for sure, but wouldn't connect. This is what left me frustrated.
Eventually, I noticed that strangely enough it saw my home network, but no others. My phone could see about 15 networks. This led me to check the RSSI of the bad device and it was showing -96 whereas an identical device that was connecting showed -48. -96 is basically unusable, so it's no surprise that it couldn't connect. Evidently, I've got a bad wifi radio/antenna on that device and am returning it for a working one.
01-07-2023 08:51 AM
What do the logs on the device that can't connect to Nest Wifi say? The client should also be able to give some insight into what happens.
01-10-2023 04:36 PM
@olavrb, appreciate your helpful response.
@MABeatty1978, chiming in to ensure everything is good here. Were you able to see olavrb's response? We'll wait for your update.
Abi
01-10-2023 06:02 PM
01-10-2023 07:45 PM
Hello MABeatty1978,
Thanks for the update. I'm happy to hear you were able to get to the root cause of the issue. Let us know if there's anything else you need help with so we can assist you.
Abi
01-11-2023 01:55 PM
Need to speak to someone
01-11-2023 04:10 PM
Hi Vtaylor,
I'm sorry to hear you're also having an issue. To clarify, what specific device can't connect to your network? Also, what device did you buy? Is it a Google Wifi, Nest Wifi or Nest Wifi Pro device? We'll wait for your update.
Abi
01-14-2023 03:44 PM
Hey Vtaylor,
We’d like to check in again in case you have any further questions or concerns. Feel free to reply to this thread and we’ll help you out.
Abi
01-15-2023 08:58 PM
Hello everyone,
Abi
01-11-2023 01:52 PM
We have tried multiple time to connect to Wi-Fi even had IT try them bought a new one and connected fine now that one will not connect , they last about 6-8 months then drop Wi-Fi and don’t reconnect have tried with home Wi-Fi and office Wi-Fi. Device will not find internet home or work. Have old one upstairs and stays connected
