12-11-2023 04:03 AM
Hi all,
I have bought google wifi and set it up in my home. I have, according to google home app, great connection in all my wifi points and the internet speed on the nest wifi router is 900 mbps download and 194mbps upload.
The problem is when i'm using the wifi points, my devices report around 40mbps of download speed.
Close to the wifi router, i have no issues whatsoever. I have tried to create a closer circuit but still, i'm unable to get more than 40-50 mbps. Can I do something to improve my experience?
The wifi router is in a direct line to my wifi point (no walls, just a couple of open doors) and they are 8-10 meters apart.
01-02-2024 12:04 AM
I have the exact same problem. Google nest speed test says 900mbps down and 40 up. Can get the same speed when laptop is connected via ethernet to router. But every device on my wifi network cannot get above about 100 - 150mbps. Very frustrating. I think the nest is limiting the speed of wifi devices.
03-11-2024 12:43 PM
Hi Nexus8,
We're sorry for the inconvenience this has caused you. We're checking in to see if you've managed to do the troubleshooting steps provided above. If so, how was it?
Kind regards,
Dan
01-24-2024 10:39 AM
Hi TiagoLopes,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? What device are you using to set up your network (iOS or Android)? Do you have the Internet on your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
