08-24-2024 10:06 AM
Hi.
I have just got WiFi pro and ordered some tp link 2400mbps powerline adapters.
will it work, and is it best to use the power line adapters to run Ethernet my two other WiFi pro points, or am I better just to let them connect wirelessly?
hope this makes sense, I’m not overly knowledgeable with all this!
Many thanks.
Adam.
08-27-2024 10:49 AM
Hi @Adamh65,
Thank you for posting in the community. As I can see right here, you need help to know if we recommend using these ''tp link power adapters'' to have a better connection or using wireless connectivity. So don't worry, I'm here to help.
My recommendation for you is to try to use the Nest WiFi Pro in a wireless connection to check how the network is working in that way, how the points will work with that connection, and if the devices work fine without any difficulty or interference.
I can't really assure you that the power-line adapters will be the best way or give you better performance because that device is not within my scope, so let's see how they work. In the event that the devices don't work as you expected, you can reply, and I will help you with that.
Please keep me updated.
Lusvin
