Battery draining on Nest Detect sensor.
rasheelr
There seems to be issue with one of my nest detect sensors. I have replaced it with Energizer Lithium Battery 123A and once with Panasonic batteries as recommended by Google. I have 4 sensors and only one sensor seems to be having this issue. I have replaced three times with new battery and only to see low battery issue recurring in 2 weeks time. Please advise
10 REPLIES 10
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed. I would make sure that you restart or Factory Reset your Nest Detects. You can learn how to do that here
rasheelr
Hello Brad, yes resetting was also one of the option tried by myself before posting for help in this community. Resetting and battery change(twice) are options I already tried.
Christophe
same here!!
I am sorry to hear that you are still having these issues with your Nest Detect! I would love to look into this for you and find a solution. Have you tried to restart your Nest Detect?
rasheelr
Hey Brad,
Yes- restart was also tried. I had to reset and setup nest detector with new batteries. Same behavior after 2 months.
At this point, I decided to open a thread with Google specialist for setting up repair help.
Rasheel Ravindran
rasheelr
Any luck here? Can we have someone quickly  looking into fix?
@rasheelr
Do you have a support ticket open then? If that is the case, then I would suggest continuing to work with them on this issue. In the meantime, restart your Detect and try to Factory Reset.
rasheelr
Thanks Brad. I will open support ticket. Do you have link to open support ticket. It will be helpful.
@rasheelr
I think it would be good to work with them to see what can be done for you. You can fill out this form here, and it will create a case and support will reach out to you.
MikeB28
I have the Nest Detect on three doors but only one of them is draining the battery every 3 to 4 weeks. I have previously tried all the solutions listed in this string of messages at the time of replacing the batteries approximately three weeks ago. However, I just had to replace the battery on that Nest Detect again today. Is there a fix for this issue?
