01-20-2022 01:40 PM
How do you charge a nest cam battery when your phone says "empty battery"? Also, why does it need to be charged since it's hard wired???
01-20-2022 02:37 PM
We have had a Google Nest Battery Camera since the first week of September 2021, plugged in all the time with the optional 10-meter weatherproof power cable. It has to be plugged in with the cable feeding to the FRONT of the camera (as odd as that seems). Our camera always shows as "Live" with a livestream video when we check it in the Google Home app. If we check Settings | Battery while it is plugged in, it says "Plugged in" and shows an infinity symbol. Only if we turn off the power to that circuit and go to Settings | Battery can we see the battery's charge level, and it always shows 100%, even on cold Minnesota days and nights as low as 17 degree below zero Fahrenheit.
You are supposedly able to charge the Google Nest Battery Camera with the enclosed short charging cord, again with the cord feeding toward the FRONT of the camera. We've never used that cord because our camera is plugged in all the time with the optional power cable.
Just sharing our experience.
04-28-2022 10:51 AM
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
