07-05-2022 06:48 PM
How do you connect your smart lock it’s not showing on the Google home
07-13-2022 08:11 AM
I am terribly sorry to hear that you're having this issue! I would love to assist you with this issue. If you are having issues with your Nest Cam or Nest Doorbell, I would suggest that you first start by restarting it.
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
07-18-2022 08:04 AM
Best regard,
07-18-2022 08:11 AM
Hi there sorry for the delay I actually got confirmation that the adt lock is not linked and only on their app
07-18-2022 08:30 AM
Well if it is not the Nest x Yale lock, I do not know if/how to install it in the Google Home app. You can just try to add the device in.
07-18-2022 08:44 AM
Yes you are correct. there was some disconnect. Thanks for following up. it is not either of the 2 you mentioned. It is an ADT brand and i was able to get them to confirm. the google product is very new to them.
07-18-2022 09:04 AM
07-18-2022 09:33 AM
Hi Brad, it states Kwikset SmartCode Z-Wave Deadblot lock, i have the now google nest hug and google doorbell included.
07-18-2022 09:36 AM
I see, thank you for the explanation! I was just informed that you will actually want to go to Support and they can help you through the installation process in the app.
07-26-2022 09:20 AM
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
07-26-2022 09:26 AM
Hi Brad you can close. thanks for the links for my specific lock through ADT not possible but thanks
