05-15-2022 01:46 PM
I just purchased a home with yale lock and doorbell camera. I figured out how to reset but i cannot figure how to connect to my iPhone. Do i need a nest connect?
05-19-2022 08:00 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I definitely understand how frustrating your situation must be, and I wanted to make sure that your concern was acknowledged. Do you still need help with this issue?
05-19-2022 09:09 AM
Yes i do
05-19-2022 09:26 AM
You would want to connect the device to the Nest App if you have it. If it is still tied to the previous owner, then you will want to reach out to them if you can to get them to remove the device from their account. Usually, people will do this anyway when a house is sold.
05-19-2022 09:52 AM
I have the nest app. Its saying i need a connector?? I want to be able to lock my door from my phone
05-19-2022 09:59 AM
I have no clue what a connector is. Is your lock functioning in full? Does it work at all? Have you tried to change the batteries if its not working? What exactly does the error message state?
05-25-2022 06:45 AM
When i try to add the yale lock to the nest doorbell it says a connector is needed. It works but i want ilthe ability to lock my door from the phone
05-26-2022 08:05 AM
It is recommended to purchase a Nest Connect with your lock as it helps it stay connected better. I do not believe it is required for the lock to function, but it is much more fluid of a process for your lock to stay connected.
05-27-2022 08:31 AM
Hey Folks.
05-23-2022 09:01 AM
Just checking in to see how the conversation is going as there's been a lapse in activity on this thread. Please let me know if you need further assistance.
