Nest Lock Not Working
Jcrewstar24
My lock says it’s offline, which isn’t unusual. What is unusual is that none of our pre-programmed codes seem to be working, and the app definitely looks different than a normal offline (which happens regularly). We’re effectively locked out at the moment, so a timely response would be great.
claywj
As no one replied, did you try the steps as if the lock were dead and out of battery (use 9v battery) and apply the master code ?
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be. I just wanted to make sure that your issue is addressed.
  • Do you still need help with this issue?
  • What other troubleshooting steps have you done thus far?
Hey Folks.
