10-21-2023 01:06 PM
Similar to other users, my Nest Yale lock battery drains in a day. I had a lock for 2 yrs and suddenly it starts the battery starts draining in a day. I contacted nest who has me do a factory reset and removal from the app. Did all that and no success. Google told me to talk to Yale as it seems like a lock issue. I called Yale they said the lock is out of warranty by a new one.
I bought a new one. Guess what. SAME )&)&;$;&( issue. I called Yale they said the install is done fine and call Google Nest because it is a software issue. I talk to Kathy from Google Nest and without even trying to help saying the battery draining is a hardware issue and to contact Yale. Piece garbage product. I have 3 Nest thermostats, 9 Nest Protect, Nest door bell. And this piece of garbage lock times 2.
GOOGLE THIS IS A SOFTWARE BUG.
Then Nest connect is 6 ft away and 10 ft from the router. All within the 30-40 ft suggested distance.
FIX THE SOFTWARE INSTEAD OF BLAMING THE HARDWARE. Two locks don’t exhibit the same behavior. The only thing in common is the software.
10-24-2023 08:16 PM
Hello Dave77,
Oh no! I'm sorry to hear that. That isn’t the experience we want you to have. Could you share the case ID from your interaction with the support team so I can check what happened?
Lance
