03-16-2023 06:29 PM
Three times I have done initial install and set up, everything works fine for about a day then shows as offline and I cannot get to connect. I will erase and setup connect and lock, will work fine for about a day than repeat same problem. Nest connect is about 3 feet from my nest mesh router and about 6 feet in direct line of sight to the Yale lock.
03-30-2023 07:36 AM
seems nobody is answering in here anymore, i have your same problem, and started about the same time, 2-3 weeks ago. now, the difference is that i cant longer connect the lock with the nest... lot of headaches trying to figure out this
04-09-2023 07:10 PM - edited 04-09-2023 07:15 PM
I’m sorry to hear that and for the delayed response here. No worries, we’ll check this out — a few questions: what’s the status light of your Nest Connect? How far is your Nest x Yale Lock and Connect from the router? Are the batteries of your lock fresh and standard AA alkaline batteries? Also, what Wi-Fi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
Here are some troubleshooting steps you can try:
Let me know how it goes.
04-12-2023 07:26 PM
It's me again. I want to make sure you're all good — how did the steps go?
04-15-2023 03:07 PM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
