Nest app have problem connecting to nest connect
Sakthi1
I have tried resetting the nest connect and Yale lock multiple times . Did factory reset also but it keeps saying the app cannot connect to assisting nest product with error T030. I looked at all other google help topics related to this . I am trying to connect nest smoke detector too and I get the same error . Is the nest connect not working. But it is connected to the nest app on the phone
sicsacol
Hi @Sakthi1,
Thanks for reaching out to the community. I understand you're having trouble adding your Nest x Yale lock and a Nest Protect to the Nest app, especially since you're getting a T030 error code on both devices, which may be happening because the Nest Connect isn't working as expected. I appreciate your troubleshooting efforts and the detailed information shared. Don't worry, let's work together to get this resolved. To help with that, I have a few questions:
  • What is the status light on your Nest Connect?
  • How far is your Nest Connect from your router?
  • How far is your Nest x Yale lock from your Nest Connect?
  • How far is your Nest Protect from your router?
  • Are there any walls, mirrors, microwave appliances, or Bluetooth devices between your Nest Connect and your Nest x Yale Lock or Nest Protect?
  • Have you already tried the steps that legendheroes shared? If so, how was it?
@legendheroes, thanks for the troubleshooting steps provided!
Any additional details you can provide will be helpful.
Jonathan
Sakthi1
hi everyone,
Thanks for the responses.i tried everything that you suggested and also checked with the team support directly.At this point they said i have to have teh device replaced.thanks again for all your support
fuionjio
@Sakthi1
  • Factory reset isn’t always enough – I had to manually remove Nest Connect from my account in the app > wait 30 mins > then re-add it like it was new.
  • Nest Connect needs to be close to both the Wi-Fi router and the device (like the Yale lock or Protect). I temporarily moved everything into the same room, connected it all, then returned them to original spots.
  • Your phone and Nest Connect MUST be on the same 2.4 GHz network. Double-check that your phone didn’t auto-switch to 5 GHz or mobile data. T030 often shows up due to that.
  • Restart your router before re-adding devices. This seems unnecessary but solved pairing issues for me.
  • Reinstall the Nest App (fresh install > log in again). Sometimes it caches failed attempts and causes a weird loop.
  • If you're using a mesh Wi-Fi system, try turning off the other nodes temporarily so Nest connects only to the main one during setup.
